LabWindows/CVI
adding a scroll bar to a strip chart???
Is there any way at all to add a horizontal scroll bar to a strip chart?
Or is there any other way to "scroll" or "view" the data in a strip chart?
Thanks in advance
Ruan
(4,788 Views)
you can set the ATTR_HISTORY_BUFFER of a stripchart and then if you set
ATTR_STRIP_CHART_PAUSED a horizontal scroll bar appears.
So, what i do is first init the strip chart:
SetCtrlAttribute (stripchartPanel, POWER_STRIPCHART,
ATTR_HISTORY_BUFFER_SIZE, 86400);
and on the stripchart panel i create a checkbox. If it is marked i set:
ATTR_STRIP_CHART_PAUSED, 1);
the scroll bar appears and you can view history data. Remove the check mark
and set:
ATTR_STRIP_CHART_PAUSED, 0);
to get actual data plot.
Greetings from Bremerhaven, Germany
Norbert Rieper
"Ruan B" <x@no.email> schrieb im Newsbeitrag
news:1208349614652-690470@exchange.ni.com...
> Hi,
> &nbsp;
> &nbsp;
> Thanks in advance
> Ruan
(4,774 Views)
Thanks for the reply,
but im not quite following with the ATTR_HISTORY_BUFFER, is there an library that i should add to my project?
Is it possible for you to post an example of this or give me a link to a site or page where i can download an example?
Thanks in advance
Ruan
(4,754 Views)
insert
#include <userint.h>
at the beginning of your code.
Search in the HELP for ATTR_HISTORY_BUFFER_SIZE
Description: The size of the history buffer for the strip chart. This
value determines how much previously plotted data is available when you
enable ATTR_STRIP_CHART_PAUSED. Pass a value that is at least as large as
ATTR_POINTS_PER_SCREEN.
Description: Enable this attribute to pause plotting on the strip
chart. When you pause plotting, LabWindows/CVI displays a scroll bar on the
strip chart, which allows the user to view previously plotted data. Specify
how many points are available to view with the ATTR_HISTORY_BUFFER_SIZE.
Only valid when the scroll mode is set to continuous.
Norbert
news:1208416213847-691043@exchange.ni.com...
> library that i should add to my project? Is it possible&nbsp;for
> you&nbsp;to post an example of this or give me a link to a site or page
> Thanks in advanceRuan
(4,731 Views)
These attributes were added to the stripchart in CVI 8.5. They are not available if you are using an older version.
Mert A.
(4,727 Views)
Thanks for the replies!
I have came up with an other solution by using the idea of a buffer and had to add a scrollbar, this is working fine since i can't really upgrade LabWindows at the momentSmiley Sad
Thanks again
Ruan
(4,698 Views)
