LabWindows/CVI
adding .chm help files to a cvi application
Hi
I would like to know if anyone can tell me how do I add a .chm help file to a CVI application, so when someone click on the help menu the help document pops up.
Regards
Simon
(3,530 Views)
Hi Simon,
There is a function that can be called from CVI that will display a .chm file. The function is ShowHtmlHelp();. By specifying the .chm file you want to use, CVI will launch that file in a standard help window.
To use this with a help menu, you can simply create a callback for your help button or menu and then put ShowHtmlHelp() into the callback. Include the .chm file with any distributions and you should be sorted!
Hope this helps,
Tom
Applications Engineering, NI UK
(3,507 Views)
Thanks Tom, yes it worked  Smiley Very Happy
Simon
Message Edited by snixon on 02-01-2008 11:23 AM
(3,485 Views)
