LabWindows/CVI
adding controls
I am trying to modify the numeric controls above and beyond changing the colors with the quick edit function.  For instance I would like to change a needle on a meter to look like a tank turret rotating.  Is there  another toolbox that I need?
(3,188 Views)
Just go to the UIR File .
Press Double Click on the control u want to edit and there u have 4 buttons on the visual view , one of them is a brush .
Press On the brush and then Press with the right button of your mouse on the part u want to change its color , then select color .
You can also change color with the SetCtrlAttribute .
For more info just look at one or two examples......
I Hope it helps
Kobi Kalif
Software Engineer
(3,156 Views)
