LabWindows/CVI
agilent 34970a example
Hello, can I can find somewhere some suitable example of data aquisition (I mean some nice function panel) from Agilent 34970a working under
LabWindows/CVI (7.1) and not only version for LabView? This will be very helpful for me... Thx in advance.
(4,883 Views)
Hi, Below are a links to the Agilent 34970a VXIPNP drivers:
http://sine.ni.com/apps/we/niid_web_display.download_page?p_id_guid=E3B19B3E92B3659CE034080020E74861
http://adn.tm.agilent.com/index.cgi?CONTENT_ID=2265
"Only a life lived in the service to others is worth living..." - Albert Einstein
(4,875 Views)
There should be some examples in the drivers from the link that Sergei provided. However, they may be for Labview, only.
If I recall, there are examples in the Programming Guide from Agilent. Look at the command list. At the bottom there is example of how the code is used.
Here is a link to the manual: http://we.home.agilent.com/upload/cmc_upload/All/34970-90003_users.pdf
You may also refer to the manuals for the plug-in modules that you are using.
-JLV-
(4,865 Views)
