LabWindows/CVI
agpsgmxg_WriteArbWaveform
I am using Agilents 5182A Rf signal generator with the agpsgmx driver that was downloaded from ni instruments driver pool
the WriteArbWaveform does not work it only checks the validity of the parameters and not doing anything else
Pleas advice
Gabel Daniel
(3,270 Views)
Hi aplication dev...,
What version of LabWindows\CVI are you using? What OS are you on? What version of the driver do you have? When did you install that version of the driver? The answers to these questions will help me get a better picture of what you are experiencing.
Perry S.
(3,260 Views)
the driver ver is 1.8 installed 2 week ago
i am working on cvi 2010 win XP service pack 3
by the way if you look into the driver source of this function you can see that the function does nothing exept checking
the validity of the params.
this topic is not relevant for me any more i have downloaded the driver directly from agilents web site & its working grate
Thank
Gabel Daniel
(3,250 Views)
