LabWindows/CVI
alter command in sql
hi,
could you please tell me is there any command in cvi like
ALTER TABLE table_name{ADD|DROP|MODIFY} column_name {data_ype};
i am getting error like undeclared identifier ALTER.
Thanks & Regards
(3,451 Views)
Look at the SQL toolkit help. You can assemble your command in a string and use the appropriate SQL toolkit function, e.g.
sprintf(sqlstatement,"SELECT * FROM `TESTDATA`.`RESULTS` WHERE ID = '%s' ORDER BY ReadingNo;", UID);
local_report_handle = DBActivateSQL (hdbc,sqlstatement );
Also Search this forum for SQL topics. e.g.http://forums.ni.com/t5/LabWindows-CVI/CVI-database/m-p/2285016#M60668
(3,431 Views)
