LabWindows/CVI
analog channel with encoder graph
Dear All,
I am doing an integration of a servomotor based press with following tools...
1. Labwindows/ CVI.
2. PCI 6221.
3. Servo motor with encoder feedback.
Now i have to plot a curve in XY graph as follows...
1. X axis with position.
2. Y axis load applied on the component.
The encoder quadrature output to be counted as poisition ( With direction) and the load cell output 0-10vdc to be connected to an analog channel of PCI 6221.
Now i have to synchronise both poisiton and load   and aquire the data and plot a XY graph.
Seeking help.
regards,
Kumar.E
Vamtec machines & Automation
India
(3,273 Views)
In this thread I proposed a solution for simultaneous analog input and counter acquisition: it is possible that it can be ported to quadrature encoder too.
(3,264 Views)
