LabWindows/CVI
anci c instruction :- system("pause"); crashing in labwindows
Hello All,
I want to pause my program while execution. My programming language is C, lex and yacc.
I tried with,
1. getch:- no conio.h
2. system("pause");   ::::: system crashing
Please help,How can I halt my program while executing?
 I am using simple printf ststements here.
Raghavendra
(4,504 Views)
If you can't use the ANSI getchar() or the CVI GetKey() functions, then maybe you can use the CVI KeyHit() function. Its in the utility library.
JR
(4,496 Views)
Because "pause" is a shell command, you should probably try system("cmd /C pause") instead of system("pause"). Also, you should probably check the Create Console Application box in the Target Settings dialog so that cmd does not spawn a new console for this.
(4,470 Views)
