LabWindows/CVI
any event is there for continues touch
Hello Sir,
im using cvi 5.5 ver.
i attached one image in that i  using UP command button.....im confused which EVENT i should use for continues preSs from finger in touch screen...
if my finger is in UP command button in touch screen...i will supply continues voltage....if i removed my finger from UP command button im not supplying voltage....
i think in CVI dont have EVENT for contiunes press...
Message 1 of 16
(6,125 Views)
Yould try using EVENT_LEFT_CLICK and EVENT_LEFT_CLICK_UP, but I'm not usre the second is already available in cvi5.5. If it's not, then you should look in the help for EnableExtendedMouseEvents function and its usage; try looking also at this example that makes use of that command.
Message 2 of 16
(6,120 Views)
is it supporing for cvi 5.5 version?
am unbale compile while using EnableExtendedMouseEvents  calling function.
Message 3 of 16
(6,036 Views)
Documentation says it's been introduced in CVI4.
Did you receive compilation/linking errors?
Message 4 of 16
(6,036 Views)
yes
Message 5 of 16
(6,043 Views)
sudhirvasudevacahrya ha scritto:
yes
Argh! Smiley Frustrated
...would you mind telling us which ones?
Message 6 of 16
(6,040 Views)
what to do?Smiley Sad
Message 7 of 16
(6,012 Views)
Plese check i attached one snap shot....
Message 8 of 16
(6,010 Views)
This command is part of the Programmer'S Toolbox, you need to add that instrument to your project, in the Instrument menu.
Message 9 of 16
(5,998 Views)
i dint get any idea how to add instrument driver,i tried many things
Message 10 of 16
(5,956 Views)
