LabWindows/CVI
anybody knoes hot to use the function Ini_WriteGeneric?
i need to write to a ini file but without deleting the old content of the file, this is why i can't use the simple function writetofile..instead i need to use Ini_WriteGeneric to write to a generic output but i can't figure out how it works...does anybody has an idea or example? .Regards.
(3,910 Views)
If you don't want to delete the previous content of the file, it's enough that you call Ini_ReadFromFile at the beginning of your function, then use Ini_Put functions to fill or replace the desired items and last use Ini_WriteToFile to save to disk.
Roberto
(3,910 Views)
Hi Roberto,
And what if I do want to replace the content instead of writing the new info at the end of the file?
I have tried not using Ini_ReadFromFile but it is mandatory before reading any info inside the ini file...
(3,505 Views)
The procedure remains the same: Ini_ReadFromFile, Ini_PutXX, Ini_WriteToFile.
If the values you manipulate with Ini_Put lines already exist in the file, old content is overwritten with the new one. Non existent values are added in memory. Ini_Write saves the entire memory content to file, keeping new values added inside the section you had added them to: the file on disk is entirely rewritten to reflect the content of the IniText object.
(3,501 Views)
