LabWindows/CVI
arithmetic checksum
Hi
I am trying to calculate the 16bit arithmetic sum of a structure data type to obtain checksum of data header of a data packet.
structure is defines as follows:
struct
u16bit synchWord
u16bit chID
u32bit dataLendth
u32bit packetLenght
u8bit version
u8bit sequence
u8bit flag
u8bit type
u8bit time[6]
}dataHeader
I am having trouble with 8bit data types. How can i concatnate those to get 16bit words to add them up? Also with 8bit array needs to be calculated with 16bit words at time.
any help will be appreciated.
(4,092 Views)
An option is to create an uint16-pointer that points to the address of your structure variable. With sizeof you can ask how many bytes the structure has. Subsequent you use the uint16-pointer to add the values from all the words (or bytes) in your structure.
However there is one minor risk: packing. The data of subsequent fields in your structure are (default) only sequential bytes if any new type starts at an N-byte boundary (http://en.wikipedia.org/wiki/Data_structure_alignment). You can pack data more dense - using pragma pack - but this also applies when writing binary files of building libraries for others. I think that your structure ik ok. Myself, I always insert some reserves (for future use) and try to start all types at an 8-byte boundary. Especially with large data packets, a few extra bytes in the header is minor overhead.
Succes, Jos
(4,080 Views)
