LabWindows/CVI
array generation with ViChar
I have the following...
void ResistanceMeasure(ViChar *CH)
          "resistance setup"
          "resistance measure"
          value = measured;
void SafeTest( )
          ResistanceMeasure("101");
          OutputResults(value)
          Delay(1);
          ResistanceMeasure("102");
          Delay(1);
I have 50 channels, I know how to do an array with integers, doubles and ect. But how can I do the array with ViChar? That is "101" , "102"..."150"?
ThanksNAdvance!
FredTest
(3,364 Views)
Hi FredTest,
I'm assume from your question that you want to use a ViChar array to hold strings. ViChar is just like Char, it simply has a VISA wrapper around it. So, just like with Char, you can create an array of ViChars pointers. For instance:
ViChar* channels[50];
channels[0] = "101";
channels[1] = "102";
You can then pass the array as a parameter to your function.
ResistanceMeasure(channels[0]);
In your function ResistanceMeasure, you can then view CH as a character array.
Matt Mueller
NI
(3,350 Views)
