LabWindows/CVI
auto-saved .tui files never deleted
Following the suggestion from Roberto here I enabled "Automatically save copy of UIR as TUI file" in CVI 2015 SP1. This simplifies the handling of UI files in git.
I have enabled the "auto backup" feature too, as shown below:
I've just noticed that there is at least one condition when CVI automatically saves a copy of the .tui file. I don't know exactly which is this condition: time interval, before compiling, before debugging, other, ...
I suppose that this happens when an .uir has been edited and not saved yet. In this case, the file is saved appending "~hhmmss" before the extension.
These files are not deleted when I save the .uir file pressing the button.
And this is annoying because git finds new file to track and I must manually delete (or exclude from tracking) them.
Is this an expected behavior?
If not, is it possible to fix this?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,369 Views)
I have the same problem. After long programming sessions there can be hundreds of tui files strewn around the directory...
(3,326 Views)
Accepted by topic author vix
NI technical support confirmed this is a bug.
CAR #624635 has been opened for this issue.
Vix
Using LV from 7
(3,295 Views)
This CAR is marked as fixed in LabWindows/CVI 2017 Bug Fix Information
Vix
Using LV from 7
(3,037 Views)
