LabWindows/CVI
autosave in pdf and autoprint
I am running a test on multiple devices,
I have created a program and it print the frontpage of labview automaticlly using a PDF printer. CutePDF
I have a copy of the report i made in EXCEL or .csv form.
It doesnt look like the same pdf page i print outs, the layout that is.
is there a way for me to print automatically, yet also save it in pdf form? (so that if in the future, i misplaced the printed paper, i can always reprint it)
also, for instant, i want to save the file in
SN_343432.PDF
SN_234343.PDF
or whatever name I desired rather than letting PDFCreator give me a predefined filename?
the reason because if we create a database, its easier to sort by SN_XXXXXXX.pdf rather than a predefined filename by PDFCreator?
if someone have a solution to this, please let me know
thanks in advance
Krispiekream
(3,594 Views)
Hi krispie,
I noticed that you posted this question to the LabWindows/CVI forum but you mention LabVIEW in the question text.  Are you using LabVIEW or LabWindows?  If you are using LabVIEW, you will have better luck getting an answer in the LabVIEW Forum.  If you are using LabWindows/CVI, please let us know that as well.  Thanks!
Stephen Meserve
(3,565 Views)
i am using Are you using LabVIEW.
Krispiekream
(3,559 Views)
This post was reposted in the LabVIEW forum here.
Stephen Meserve
(3,542 Views)
