LabWindows/CVI
bradcasting messages with TCPIP library
Hi, guys.
I have a server application that manages several clients that sends data to the server. I use a socket to make the clients the server is active, but when the server shutdowns the socket state changes (a flag), and the clients connected to that socket knows the server has finished his service, but i need to broadcast message to an active port on all client machines (like port number 100) using TCP/IP library to advice the server hs initiated his service, how can I ,make that?
(2,950 Views)
Hello
This discussion sounds similar to what you might need.
Bilal Durrani
NI
Bilal Durrani
NI
(2,950 Views)
