LabWindows/CVI
build project causes CVI to crash
I have recently installed Lab Windows CVI 2009 (9.1.0).  Certain projects when I go to build them cause CVI to crash.  There is no error message or any indication what went wrong.  These same projects used to work under Lab Window 8.  I have tried re-creating the project and it still causes CVI to crash.
Has anyone seen this problem?
Operating System: Windows XP SP3.
Garth
(3,272 Views)
Hi Garth,
I was wondering if any projects build successfully. For example, can you build one of the example programs that ships with CVI?
Hassan Atassi
Senior Group Manager, Digital Support
(3,246 Views)
Hi Hassan,
Yes, I can build other projects.  It seems related to the installing of ni-visa 5.0.3.  I re-installed Lab Windows CVI 2009 and the project would build fine. But I was having issues with ni-visa specifically NI SPY it would start up but always stay minimized no matter what I tried.  So I reinstalled NI-VISA, and I had the same issue with building the project.  I re-installed Lab Windows CVI and the project will build again.  The project that would cause CVI to crash did make use of the VISA libraries.  NI-SPY still will not maximize itself.
Garth
(3,224 Views)
It's possible there is a problem with the LabVIEW run-time engine that NI Spy runs off of. Try reinstalling the run-time for LabVIEW 2009 SP1 found below.
LabVIEW Run-time 2009 SP1
(3,193 Views)
