LabWindows/CVI
calculating autopowerspectrum from fft
I'm trying to get the AutoPowerSpectrum using only FFT (I know it's wierd but I have to). When I compute this
FFT(A)FFT*(B)/N²
I don't get the same amplitudes than those computed by the AutoPowerSpectrum function.
Why is that?
Any help on the algorithm would be greatly appreciated
(3,444 Views)
Ok folks, I found the answer myself,
the autoPowerSpectrum is single-sided. This means that it returns an array that stops at SampleRate/2. Althought the FFT returns a two-sided complex array, when canceling the second half to switch to single-sided, all values have to be multiplied by 2.
I didn't quite notice because I was looking at the RMS value of the returned spectrum.
Bye folks
(3,444 Views)
