LabWindows/CVI
calling function with function like parameters
Hi guys,
is it possible in CVI make somthings like this ???
I'd like call functB with address of functA like parameter
file A
int functA (int param1)
return i
file B
void functB ( int *functA)
i=functA(x);
Thank's for your help
Marco
(3,745 Views)
Yes, this is possible in C using function pointers. For example:
void functB ( int (*)(int) f)
i = f(x);
You will call functB as:
functB (functA);
OR
functB (&functA);
Both the above are equivalent. Refer to any good C book for function pointer declarations.
(3,719 Views)
Correction:
functB should be:
void functB (int (*f) (int)
i = f(x);
(3,718 Views)
Hi Marco,
have you already tried this with other compilers?
CVI is an ANSI C based programming interface, therefore if you can do it with other C compilers you shoud be able to do it in CVI.
Is there any particular issue you want to verify?
Thanx and...Happy New Year!
RaffaL
(3,716 Views)
