LabWindows/CVI
can I create callback funtion for a newctrl ?
On the panel i create a command button by using NewCtrl();now i want to add a callback funtion for the newctrl, is it possible?if can ,how?
thanks for any help!
(3,140 Views)
obviously the callback function must exist, and therefore you know what it is called.
With this, you simply call
SetCtrlAttribute(panelHandle,controlID,ATTR_CALLBACK_FUNCTION_POINTER,functionname);
Hope that helps
S.
// it takes almost no time to rate an answer Smiley Wink
(3,140 Views)
Another possibility is to use InstallCtrlCallback, which in addition permits you to assign a value to the callbackData parameters in one call only.
In both cases, the function has the structure of the functions created by the uir editor.
Roberto
(3,140 Views)
