LabWindows/CVI
can I use NI Device Driver 2019 with LabWindows2010
I am working on legacy software using LabWindows2010. I was given NILWCVI2010.exe to install.  I am asking, can I use NI Device Driver 2019 with it
I tried to download NI Device Driver August 2011 and it took forever.
Thank you,
Qing
(2,677 Views)
If I understand correctly, NI Device Driver 2019 doesn't support LabWindows2010.
NI System Driver Set April 2019
For example, it has DAQmx 18.6 but it also doesn't support LabWindows2010. Up to 2012.
Certified LabVIEW Developer
GCentral
(2,628 Views)
Thank you, Emboar.
Si I finally downloaded August 2010 version of Device Driver.
(2,552 Views)
