LabWindows/CVI
can not create xml domdocument
错误-1074130432发生于 niscope initialize.vi
可能原因
The specified configuration store file could not be deserialized.
IviConfigserver.IviConfigStore.1:Deserialize failed.Can not create XML DOMDocument .Please check your XML parser installation.
发生这个错误该怎么解决。。。。
(3,291 Views)
there is a little mistake - you posted your question in the wong forum Smiley Happy You should choose LabVIEW and not confuse it with LabWindows.
(3,285 Views)
