LabWindows/CVI
can not find "tsutil.h"
where I can get "tsutil.h" file? I use cvi8.0 and it said not found when I include this file,thanks in advance.
(3,253 Views)
You can go to your project window, then click 'edit', then 'add files to project' and then browse to and select the file. If you don't know where you file is, try a search for it. Is that what you were asking?
(3,240 Views)
