LabWindows/CVI
can not find the imaqReadBarcode2 function in VDM 2015 nivision.lib
Hello
I use the vision assistant to verify read barcode function and generate the c code. but when I compile this code with VS 2012 I get a error that show me "error LNK2019" it cna't find the export function in nivision.lib. I checked the document "NIVisionCSupport.chm" I can find the function information about imaqReadBarcode2 and imaqReadBarcode3. So which lib I need? or how to fix this problem?
thanks
environment : VDM 2015
Lib : nivision.lib
(3,864 Views)
This is a bug and we will post a patch soon. I will add the link to the patch when it becomes available.
(3,813 Views)
