LabWindows/CVI
can't find cvintdrv.sys in cvirte7.0
As I know:
cvintdrv.sys is the Low-level support driver for Windows 2000/NT.
But when I install cvirte7.0 in WinXP(using cvirte70.zip downloaded from this website), I can't find this file. Also the inp(),outp() can't drive data to parallel port.
If I install the runtime engine with a distribution kit generated by CVI, the I/O problem seems disappear.
Does anyone encounter this?
How to explain then?
Thanks!
Echo
(3,505 Views)
Hello Echo
The cvirte on the website does not contain the low level support driver. It only provides the basic CVI Run-time components. If your application needs to distribute the low-level driver support, you should create a distribution kit for your application and in the Create Distribution dialog, select the Install Low-Level Driver Support checkbox. This will ensure that whoever uses your distribution kit will have the driver support installed.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,505 Views)
OK, I see.
Thanks a lot!
Echo
(3,505 Views)
