LabWindows/CVI
can't open UIR after changing font setting
I have a weird problem here: I can't open my UIR file. It said there's something wrong with "Attribute". It was developed on another machine and worked well there. Unfortunately the labwindows was uninstalled from it,o.w. I can go through its settins. The only thing I can think of is that I changed the default font setting from "NIDiagMetaFont" to "Tahoma" on the old machine(I tried to get a constant font display). Will it be the problem? How can I fix it?
wmf
(3,139 Views)
wmf,
If you attach the problem .uir file here, we might be able to figure why CVI is complaining about it.
Luis
(3,134 Views)
Are you trying to open the file in the same version of CVI as it was created in?
Regards
Ray Farmer
Regards
Ray Farmer
(3,085 Views)
