LabWindows/CVI
can we generate millivolts using pci 6723 card
HI,
Can I knw how can we generate a analog input in Millivolts using PCI-6723 card.
Using the below function I am able to generate volts in the range -10 to 10 v
.DAQmxCreateAOVoltageChan(*taskHandle,"Dev1/ao0 : Dev1/ao1","",min,max,DAQmx_Val_Volts,NULL);
In the above function 5th parameter is used for generating analog input in volts but I would like to generate a millivolt.
Plz reply me ASAP
Regards
krishna
(3,508 Views)
If you call a function such as DAQmxWriteAnalogScalarF64(), the parameter float64 value is a floating point number.  So to output 100mv you would set 0.100 as the output value.
(3,495 Views)
Alternately, you can create a custom scale like this:
DAQmxCreateLinScale("mV scale", 0.001, 0.0, DAQmx_Val_Volts, "mV");
then use that scale name when you create your channels:
DAQmxCreateAOVoltageChan(..., DAQmx_Val_FromCustomScale, "mV scale");
If you use the custom scale as I've described, make sure that the min and max values you pass in to
DAQmxCreateAOVoltageChan are in mV (i.e. 10000 instead of 10).
Mert A.
(3,490 Views)
Thanks for reply
Its working now
Regards
krishna
(3,467 Views)
