LabWindows/CVI
change radio button size
I have seen a few posts with this topic, but I still am unsure of the answer.
Using LV 7.1, is it possible to change the size of the radio button itself (not the text or the button cluster), but the actual round button.
Any insight is greatly appreciated.
(3,303 Views)
Inside LV 8 I found no way of modifying the size of the radio button inserted inside the "radio buttons" cluster. Instead I can modify the size of a single round radio button (found in Classic boolean palette).
Speaking of CVI, I don't think you will be able to modify the size of the single button in a radio group of toolslib controls palette, since it relies on a feature of the tree control (specifically the mark type attribute of the tree items).
You could try to emulate the behaviour of a radio group control using multiple radio buttons (which can be customized individually) adding a callback function that manages the state of individual controls when clicked.
(3,291 Views)
