LabWindows/CVI
changing DAQmx channel gain
(Windows XP, LabWindows/CVI 10, PCIe-6361).
I set up a DAQmx data acquisition task in MAX, with the voltage range set for each channel, but the user wants the option to change the voltage range in the program. So I put in:
               //some stuff
               x = new max or min value
               bMax = 1 if setting Max, 0 if setting Min.
                //stop task
                status = DAQmxStopTask (Level1_Task_p->DAQTask_Handle);
                //update value
                status = DAQmxSetChanAttribute (Level1_Task_p->DAQTask_Handle,
                                                ChannelInfo[channel].ChannelName,
                                                (bMax) ? DAQmx_AI_Max : DAQmx_AI_Min,
                                                x,
                                                1);
                //confirm value
                status = DAQmxGetChanAttribute (Level1_Task_p->DAQTask_Handle,
                                                &x,
                                                1);
                //some other stuff
                //restart task
                status = DAQmxStartTask (Level1_Task_p->DAQTask_Handle);
It stops the task, sets the max or min value of the channel (you can only set one at at a time) to the value of "x", confirms the coerced value by reading it back, and restarts the task.
The problem is that it can only set the voltage range heigher, never lower. I have the max and min nominally set to +5 and -5 V. If I enter 10 for the value, it reads back as 10. If I then set it to 1, it reads back as 10.  Any ideas would be appreciated.
(3,325 Views)
Hi pblase,
You should be able to achieve this functionality by clearing the task and creating a new task with the new amplifier settings and starting that task. This would be a solution as long as the amplifier settings are not being changed very quickly, like in this case when the user decides to change the amplification setting manually.
Milan
(3,311 Views)
