LabWindows/CVI
changing printer settings on Win2000
Thanks for this useful service!
I have a test program written in CVI5.0 and it generates a print out. Initially it was running on a Win98 PC and the program could correctly set the printing font and size. After I upgraded to Win2000 the printer started to type using an ugly (not monospaced) font and I can not change it within my program. However, if I open the saved test log (which is a .txt file) using Notepad, set the font of Notepad to Courier and print it using File-Print menu, everything goes fine and I get a neat printout. I am using SetPrintAttribute function in my program.
Do you have any suggestions?
(3,748 Views)
Hi erenbalci,
Since each operating system has its own set of printer drivers, it is possible that the newest driver you have is implementing a newer version of the GDI API. However I'm not entirely sure this is the reason why you're not able to change the font programmatically. Are you able to print a source file from within CVI? When the print dialog window comes up, can you change the font?
And finally, what do you mean by "I cannot change [the font] within my program"? Do you get an error?
If possible, can you post some simple code that shows how you're configuring the font and size properties?
Azucena
(3,748 Views)
Hi Azucena,
I found the problem and corrected it. It was my code, not the OS.
Thanks for your interest!
(3,748 Views)
Sure thing. Glad to hear you got it fixed!
(3,748 Views)
