LabWindows/CVI
clang __TIMESTAMP__
officially the clang macro __TIMESTAMP__ is defined to the date and time of the last modification of the current source file.
I found that using CVI2015 this macro gives meaningful, i.e., correct results only if the source file is saved just before compilation, otherwise it shows Thursday Jan 1 1970 at 1.00.00. I would have expected to see the date/time of the last save.
Just for your interest
(5,020 Views)
Hi Wolfgang,
thank you for reporting this behavior. I checked it on my machine and will fill a CAR for it.
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(4,989 Views)
Hello Melanie,
this bug is still unfixed in CVI2015SP1. Could you please provide the CAR for easier tracking? Thanks
(3,871 Views)
Hi Wolfgang,
the tracking number is 543786, sorry I forgot to post it.
The target version for fix is not known at the moment, so you are correct, it is not fixed for 2015 SP1.
Best
Melanie Eisfeld
(3,868 Views)
This issue is one of the few that has been fixed in CVI 2017 Smiley Happy
(3,114 Views)
