LabWindows/CVI
clean build
I have a problem using lib files created also by labwindows.
The problem is I have a function in my lib file and I change let's say, a timeout.
When I use this lib file in another projet and use the function with a new timeOut, I don't see the changes.
Looks like it's still with the old timeout!!
Is there a way to make a clean build so if I change anything in the lib file, I see the difference in the other projets that uses this lib file?
(3,367 Views)
Hi Goncalo,
What version of CVI are you using? What is different between the projects where it works on and on the project where it does not? Let me know.
Perry S.
(3,353 Views)
