LabWindows/CVI
code giving inconsistant results
I am having trouble with a piece of code. It works about 50% of the time. I have a struct defined as
struct strSCs{
char szCampaignName[20]; //campaign running on IP address
char szIPAddress[20];
char szIPAddressSelf[30]; //ip address that SC thinks it is
int iAbandonRateTarget;
int iAbandonRateCurrent;
int iNumRingsNoAnswer;
char szOnDate[20];
char szOnTime[20];
char szSCUser[15];
char szMinutesLeft[10];
char szMessageFile[80]; //message for this camp
int iValue; //this is for the listing on the uir
int iAutodialerLines; //lines used as autodialer
int iAgents; //agents logged on
int iHandle; //TCP handle
char szRandom[20];
char szCallerIDNum[20]; //from SC
char szCodec[5]; //from SC
int iCampDoneFlag;
int iMonitorOn; //0=monitor off 1 = monitor on
time_t timeHeartbeat; //last heartbeat
int iDigitsInPhone; //number of digits to dial
int iSCOffset; //this is the offset from 15900 that this camp is running
IniText itScript; //handle for the script
// char *pszScript; //pointer to the script
char szScript[15000]; //was 5k now it is 15k
int hScript;
IniText itFields; //handle for the fields
// char *pszFields; //pointer to the fields
char szFields[1000];
int hFields;
IniText itResults; //handle for the results
// char *pszResults; //pointer to the results
char szResults[5500];
int hResults;
int iP2P; //use P2P
int iServer; //use server
int iP2PHandle; //handle for SC to Gateway in P2P
int iNextAgentHandle; //next agent to use in a Pass
int iPersonalMessage; //flag to showwhether to use personal leave message 1=yes
int iAgentsTalking;
int iAgentsWrapping;
int iAMD; //flag to use AMD
int iAbandMessage; //use an abandon message
}strSCMember,*pstrSCMember,*ptrMem;
At some point in my main() code I am starting up a thread:
iRc = CmtScheduleThreadPoolFunction (DEFAULT_THREAD_POOL_HANDLE,
ThreadFunctionResultsWrite, (void *)ptrMem,
NULL);
It correctly starts up this function:
int CVICALLBACK ThreadFunctionResultsWrite (void *ptrMem)
IniText itR;
int iHandle;
char szBuf[255],*pszPtr;
char *pszResults;
char *pszMem;
pszResults=((struct strSCs*)ptrMem)->szResults;
if (strlen(pszResults)==0)
goto again;
Now, I always seem to get the buffer ptrMem being passed in correctly. I know because I can look at it with the debugger in the view memory. But SOMETIMES strlen(pszResults)==0. Now when I stop it in the thread and I look at ptrMem, I see the proper info in the view memory (which is just a string), but the first byte of pszResults equals x00. What is wrong or how can I go about fixing this?
(3,070 Views)
It is very strange that your code fails just sometimes. When problems happen just sometimes it is most likely due to threading problems. The first thing to check is no other part of the code modifies that memory space; you may want to set a thread safe queue or a thread safe variable to avoid problems with some other thread messing up the struct.
You can use the CmtWaitForThreadPoolFunctionCompletion to run the function syncronously to check if the problem is related to problems with another thread modifing the data.
I hope that helps!
Juan Carlos
N.I.
(3,070 Views)
