LabWindows/CVI
coments in INI files
I wrote a programm that read & writes to INI files,
but the problem is that after writing to file all the coments are erased. I've succeeded to keep some of the coments by setting tokens but not all of them
(3,080 Views)
The way inifile driver is written removes comments after writing to the file. All the source code is available in the same directory. You can modify the source code so that it can preserve the comments.
Mika Fukuchi
(3,080 Views)
