LabWindows/CVI
comment crée un fp labwindow CVI
(3,556 Views)
CaptainWess,
Si tu as de la difficulte a comprendre l'information que Al a offert en suivant les liens, simplement le mentionner dans cette discussion et je vais essayer de t'aider.
Creer un "front panel" (paneau) est assez simple en utilisant CVI.
R
(3,522 Views)
Captain Wess:
Did you mean function panel or front panel (as in LabView or a VISA Soft Front Panel)?
A CVI function panel gives a nice interface for programmers to easily add function calls to their programs.
A CVI front panel is called a User Interface or UIR, and you simply create one from the File >> New menu in the CVI project window.  You add controls by right-clicking on a blank spot on the panel, and selecting a control from the list.
Many times I fell inadequate not being bi-lingual (knowing CVI and LabVIEW doesn't make me bi-lingual).  If my English responses aren't helping, I will bow out of the conversation.
Au revoir
(3,515 Views)
Hi Al,
You should not feel bad about not being bilingual and you should never stop posting because of it.  🙂
Your a great contributor to this forum and your help is always greatly appreciated.
I wasn't too sure about fp.  It could be function panel, or function pointer, or front panel (UI), or fixed point, or faux pas 😄
I hope you did not misinterpret my reply.  I simply wanted to say that if something was not understood, I could step in to offer translation services 😉
R
(3,498 Views)
