LabWindows/CVI
communication between VC++ and cvi
I want to transfer the entries in an edit box of a vc++ program to an edit box in a cvi program or vice versa.Here I am attaching a code written in vc++. I want similar things between a vc++ program and cvi program.
(3,079 Views)
Hi Tupai,
Are the two programs running simultaneously, or can the VC++ program launch the CVI program?  As a starting point for the former, I would look at the examples in the Example Finder under Communicating with External Applications >> ActiveX << SimpleEventsClient[Server].  Also, there are more examples under the General section of ActiveX.
For the latter, the easiest implementation would be to pass the string as a command-line argument.
Cheers,
David Goldberg
Software R&D
(3,048 Views)
