LabWindows/CVI
compatibility CVI7.0 and CVI7.1
I have make an application toto with CVI7.0 on my (developpement) PC(W2K).
I have distributed this to my client ,runtime on a PC(W2K)
I have updated this application on a new PC developpement (XP) with CVI 7.1.
Can I just copy the updated  toto.exe on the target PC as before.
thanks for your answer.
didier.
(3,031 Views)
The CVI Runtime Engine is designed to be backwards compatible, which means that if you have a newer version of the RTE, an application that was created with that version or an older version will work.
There might be problems however if you try and use a exe built with a newer version of CVI with an older RTE. I would recommend distributing the new 7.1 RTE with your application.
Bilal Durrani
NI
(3,023 Views)
