LabWindows/CVI
compatibility problem with MS Access ? HELP please
Hello, i'm french
I have created under labwindows a program which is connected with ms access under labwindows 7.1, with the sql toolkit then have created an achievable (.exe) with the run time engine. That works very well when I pass it on my (leg? portable?) computer , without forgetting the bonds odbc towards my base.
HOWEVER when I pass on another computer having ms Access 2002, when I try to connect  to the base, it turns over an impossible connection. Is this normal? Moreover, for the connection, I followed the example of connection to the base of data provided on the site of Ni and it is indicated that it works only with ms Access 97.
Considering that it does working with 2003 I thought that that functioned with all? If it doesn't, is there a means that that functions with all the versions of access, for a better portability?
Thanks for agreeing to light my lantern....
(3,125 Views)
you'll find the answer at the link below:
Benjamin M
(3,076 Views)
