LabWindows/CVI
control mode fonts
Why does the font colour and background colour of controls change when swapping from indicator to hot control mode?
Is there any way of preventing this change?
Many thanks for any replies
(3,165 Views)
This is a visual reminder of the control mode, to let the user distinguish between operable and non-operable fields.
To prevent this you can only set those elements after changing the control mode via the proper attributes.
You may have noted also that if the control lable is on the left of the control itself, it will be shifted by some amount of pixels when changing from hot to indicator and vice versa.
(3,160 Views)
