LabWindows/CVI
controlling a numeric slider with numeric control problem
what i have is a numeric slider and a numeric control.  i would like to be able to move the slider and have it update the value in the numeric control and vice versa.  the problem is that i can update the value in the numeric control when i move the slider, but i can't update the slider if i try to change the value in the numeric control.  i was trying to use the 'value' property node for each of them and and wire each of the controls to the opposite property node.  i know they are both control but i thought if i change the 'value' to an input then it may update.
i have attached the vi.
thank you
(3,564 Views)
I believe you meant to post this on the LabVIEW forums. This is the LabWindows/CVI forums.
Best Regards,
Jonathan N.
(3,557 Views)
whoops, i thought i did.
thanks
(3,551 Views)
