LabWindows/CVI
converion of microsoft visual c++ project to lab windows cvi
Is it easier to convert a Microsoft Visual C++ project into Lab Windows CVI project? Sample codes wich came with COTS card are in C++. Is there a tool in Lab Windows CVI to convert them into C files.
Suni
(3,183 Views)
Not that I know of.
Sometimes a "C++" module isn't much more than a "C" module since it's possible to write procedural code in C++ and not use classes and objects.  If your sample project doesn't use classes or objects, then it'd be a simpler task to convert it to C, which CVI uses.
The GUI operation / event model is different between the two development environments, and if there's a substantial GUI it's likely that could be the hardest to get converted to CVI.
Why do you need to convert to CVI?  Especially if it's just a sample project?
Do you have a "C" interface to the COTS card?  If not, converting the sample project to CVI and C won't do you much good.
Someone from NI can probably speak to the issue of VC++ and CVI interoperability better than this, but I think getting the VC++ project running in CVI could be a big task and not worth the cost.
(3,172 Views)
Thanks for the reply.
COTS card came with all the header files which is in C. Just the sample applications came with C++ because those have GUI's. I am used to using Lab windows CVI and i need to integrate another COTS card to the system which has C files. Now i am trying to come up with sample program in  Lab windows CVI using those header files. So lab windows user interface is not the same as GUI in c++?
(3,158 Views)
Nope, they're different.
You could build and run the VCPP project and take a look at the GUI, then recreate the panels and controls in a CVI project.  This is quite doable if you have a simple GUI.
Since you have a "C" interface to the COTS software, you can invoke that interface from CVI - I've done this with COTS libraries.  Pick a simple function out of the COTS library that has an observable effect and see if you can get it to run from a simple CVI project.
(3,152 Views)
