LabWindows/CVI
convert C string in to BSTR with CA_CStringToBSTR()
I want to convert C string in to BSTR format with function CA_CStringToBSTR.
I call an ActiveX function. In this function is CA_CStringToBSTR called.
------------ActiveX Function ---------------------
HRESULT state;
char buf[50]="0.0";
BSTR bstr=0;
state = CA_CStringToBSTR(buf, &bstr);
return ......;(0x80070057 error code "Wrong parameter")
___________________________________
Debuger after this Fun gives me the following result: state=0, bstr=0xXXXX(48)(No size Info)   [48=0x30='0']
Then I get error from this ActiveX function. I think the problem is here with this CA-CStrng..... Function.
Is that correct, what does this function?
Message 1 of 1
(3,112 Views)
