LabWindows/CVI
convert a Hex string, like "3A4B" to a string of BIN_MSB,BIN-LSB,ASC_MSB,ASC_LSB,BCD_MSB,BCD_LSB,SGN_MSB,SGN_LSB respectively
I'm looking for an easy way to convert a Hex string, like "3A4B" to a string of BIN_MSB,BIN-LSB,ASC_MSB,ASC_LSB,BCD_MSB,BCD_LSB,SGN_MSB,SGN_LSB respectively. Is there any available function I can use in CVI rather than writing some codes myself.
BIN_MSB       //A binary number stored with the most significant byte first
BIN-LSB       //A binary number stored with the least significant
ASC_MSB,     //  An ASCII number stored with the most significant byte first
ASC_LSB,     //  An ASCII number stored with the least significant byte first
BCD_MSB,     //  A BCD number stored with the most significant byte first (8421)
BCD_LSB,     //  A BCD number stored with the least significant byte first (8421)
SGN_MSB,     //  A signed hex number stored with most significant byte first
SGN_LSB     //  A signed hex number stored with the most significant byte first
Thanks!
Jacky
Message 1 of 1
(3,486 Views)
