LabWindows/CVI
convert hexa to ascii
i converted this trame "444C4D535F436F6D6D616E6420313520C101C10046000060030AFF040016000A" to ASCII but i can't
 found the right conversion in which i must found a special caracter like Â,Â,¬,...
What is the best way to convert a hex to ascii?
Thx for your help.
(5,087 Views)
ASCII encodes 128 well-defined characters in 7 bit integers, see here, the Angstrom symbol and many other symbols do not belong to this code...
Also, this is a forum about CVI, not about learning coding in C, so you should add some question specific to CVI Smiley Wink
Searching for strtol may be rewarding... Smiley Happy
(5,082 Views)
I have written a CVI app., which i convert this trame from hexa to ascii but only the special characters dont displayed on the terminal. So i want to khnow if the conversion of some special characters is possible or no!
Thx
(5,074 Views)
If your frame encodes ASCII, then it cannot contain angstrom and other symbols. You might want to read about the complex subject of encoding. Start with "man iconv"
(5,034 Views)
