LabWindows/CVI
convert number to letter of alphabet?
Is there a LabWindows function for converting a number to an alphabet equivalent?
I was trying something like this...
char getLetterOfAlphabetByNum(int number){
    //test if alpha
    if(isalpha (number)==0)
        DebugPrintf ("Error converting number to letter. Non-alphabetic.");
    else{
        //take decimal and convert to ascii
        statusReturned=Fmt (&letter, "%s<%d", number);
        if(statusReturned<0)
            DebugPrintf ("Error converting number to letter!\n");
        DebugPrintf ("tempString = %s\n", letter);
    DebugPrintf ("%d --> %s\n",number,letter);
return letter;
Thanks!
(7,816 Views)
Supposing you want to obtain the ASCII character corresponding to a given int number, you could use
sprintf (string, "%c", number);
You will need to validate the input number to be <= 255, next to see if the character is printable (which not necessarily means it's alphabetic: you must consider numbers, punctuation and other printable characters like ([{*@# and so on: isprintf and isgraph functions can be of help)
(7,815 Views)
Accepted by topic author TurboMetrologist
Thanks, this was my solution. Passing a 4 gives a 'D', for example.
//number of alphabet to letter
    number=number+64;
    //test if alpha and printable
    if(isgraph(number)==0){
        DebugPrintf ("Non-printable character.\n");
        return;
    if(isalpha(number)==0){
        DebugPrintf ("Non-alphabetic.\n");
        return;
    sprintf (&tempString[0], "%c", number);
    letter=tempString[0];
    DebugPrintf ("%d --> %c\n",number,letter);
return letter;
(7,806 Views)
It seems to me that you could simplify your code this way:
char getLetterOfAlphabetByNum (int number)
    number += 64;
    //test if alpha
    if (!isalpha (number)) {
        return 0;
    return (char)number;
I excluded the test for printable characters as is it overcome by test for alphabetic.
Also, be warned that passing numbers from 33 to 58 returns lowercase letters.
(7,774 Views)
Thanks Roberto
(7,717 Views)
You can do this, too:
number += 'A';
/* Nothing past this point should fail if the code is working as intended */
(7,680 Views)
