LabWindows/CVI
convert
Is there anyway to convert an int array into char array? I tried using the ConvertArrayType function but it doesn't seem to work. Any help would be appreciated.
(3,988 Views)
If you want to convert an array of integers into an array of strings (i.e. from { 1, 2, 3, ... 618 } to { "1", "2", "3", ... "618" } ) then your only solution is to loop through array elements and sprintf the corresponding string into the array of strings.
(3,979 Views)
