LabWindows/CVI
copy chart from excel to image
I would like to know if it's possible to copy to clipboard a chart from an excel sheet.
I would like to copy this image to a picture object on a panel to show it to the user.
If yes, how?
(1,393 Views)
[PrintScreen] key, paste into any graphic application, Crop, [Copy], [Paste] into UI image object.
(1,361 Views)
I need to do it automatically, not manually.
I know that in vb, you can do the following command :
Workbooks(1).Sheets(feuille$).ChartObjects("Graphique 1").CopyPicture
Once you do that, it's available in the clipboard.  So i can get it using cvi clipboards command.
(1,358 Views)
