LabWindows/CVI
copying formule from one cell to other cell using cvi
hi,
how to copy formule from one cell to the other cell in the excel sheet using cvi functions.
Thanks & Regards
(3,309 Views)
First, I assume you have studied the example CVI project "excel2000dem.prj" that comes with the installation of your LabWindows/CVI.  From this example, you know how the function "ReadDataFromExcel(...)" function in excel2000dem.c works.
Now, suppose you have a formula "=D3+E4" in cell "D35" and you want to copy this formula to cell "Z9".  Here's how you do it.
// 1) Get a formula from a cell D35.
    // Open and activate one cell only
    error = CA_VariantSetCString (&MyCellRangeV, "D35");
    error = Excel_WorksheetRange (ExcelWorksheetHandle, NULL, MyCellRangeV, CA_DEFAULT_VAL, &ExcelSingleCellRangeHandle);
    if (error<0) goto Error;
    // Make range Active
    error = Excel_RangeActivate (ExcelSingleCellRangeHandle, &ErrorInfo, NULL);
    // Get the value of the Single Cell Range
    error = Excel_GetProperty (ExcelSingleCellRangeHandle, &ErrorInfo, Excel_RangeFormula, CAVT_VARIANT, &MyVariant);
    error = CA_VariantGetCString(&MyVariant, &str);
    printf("%s\n ", str);          //<--- the formula in now stored in the character array "str"
   Error:
    CA_VariantClear(&MyVariant);
    CA_VariantClear(&MyCellRangeV);
    ClearObjHandle (&ExcelSingleCellRangeHandle);
    if (error < 0)
        ReportAppAutomationError (error);
    return error;
// 2) Write a formula to a cell Z9.
    error = CA_VariantSetCString (&MyCellRangeV, "Z9");
    error = Excel_WorksheetRange (ExcelWorksheetHandle, NULL, MyCellRangeV, CA_DEFAULT_VAL, &ExcelRangeHandle);
    error = Excel_RangeActivate (ExcelRangeHandle, &ErrorInfo, NULL);
    error = Excel_SetProperty (ExcelRangeHandle, &ErrorInfo,
                               Excel_RangeValue2, CAVT_CSTRING, str);
   Error:
    ClearObjHandle (&ExcelRangeHandle);
    if (error < 0)
Again, you have to study the example code in excel2000dem.c to educate yourself about how CVI works with Excel.
(3,278 Views)
