LabWindows/CVI
counter timer setup for DAQCard 1200
is it possible to set up a square wave generator using an internal clock and a counter other than '0'?
thnx in advance
MJH
(3,342 Views)
The three general purpose counters on the DAQcard-1200 can all be used for square wave generation. However, as you question is hinting on, only the first counter can be used with an internal clock. For these applications, the CLK and GATE signals at the
front I/O connector control the counters. The single exception is counter B0, which has an internal 2 MHz clock. You must use signals connected to the I/O Connector to provide the necessary signals to your other counters.
Jared A
(3,342 Views)
Yes thanks Jared. That's about what I thought too. (Makes if difficult/impossible(?) using the A/D and having square wave generation (with internal clock) at the same time as they both use counter B0 it seems.)
regards
michael
(3,342 Views)
