LabWindows/CVI
create a own class
Hallo to everybody,
I want to create some own classes, but I only know it in "MS Visual Studio". How can I do this in LabWindow?
Perhaps you can give me also a help for creating the following objects and how I can call them later.
Thx a lot
Flo
(3,070 Views)
Hello Greber,
If you are referring to classes in the C++ realm, LabWindows/CVI is an ANSI C programming environment, so you would not be able to directly create C++ classes. You can create you classes in C++ and use your code in CVI, if you create a C dll and use extern "C" to prevent name mangling.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,044 Views)
