LabWindows/CVI
create excel macro using labwindows api
Hi All,
I need to create an excel macro using labwindows api. Then, i need to run this macro. I can run this created macro using ExcelRpt_RunMacro(ExcelRpt_RunMacro
CAObjHandle applicationHandle, char macroName[]). But, in order that i run the macro i need to create the macro first. So, how can i create an excel macro using labwindows.
Can anyone help me in doing this?
This is very urgent.
Thankyou in advance.
Safer
(3,555 Views)
This should help you get started.
Example Finder under Communicating with External Applications >> ActiveX >> Excel >> excel2000dem.prj
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(3,532 Views)
